maybe MB can also look for a .jpg named as the folder name. I realise this will not be obvious to users but hopefully some skin authors will bundle a background with their skin, that follows either naming convention so if the user opt's into using background images (once i make it a tick-box) that will serve as the default for the skin
I am planning to add some custom bg images to 3.2 skins of mine. But the auto-loading following the skin name feature no longer works. Can you fix it?
Also some further suggestions:
- Panel header on the sidebar would look better if they are translucent just like the main header bar. Tabs bar and status bar too could get the same treatment to a lesser degree.
- Tag editors (either the docked one or the vertical) are not affected at all. They could look the same as the main panel or other sidebar panels.
