Please add the ability to disable this panel, it takes a lot of space.
+1; however, I'm assuming it was meant that this wouldn't be removable specifically in the test version. (Sizewise it takes up more space than elements with far greater utility, eg. column browser / whole row of album covers)
Also, got two more bugs to report:
1. If, as you scroll through Album Covers view, you run into a Cover that doesn't have maximum height / adequate aspect ratio, the empty space gets filled with a part of the entity above it.
2. Clicking on any album after that:
EDIT: Both seem to only occur with "Overlay fields inside artwork" setting.
