hi,
i'm getting this error qhwn i try to copy a song to my ipod touch
MusicBee v3.1.6483.18457 (Win10.0), 3 Oct 2017 12:23:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'iTunesLib.IITIPodSource'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CF4D8ACE-1720-4FB9-B0AE-9877249E89B0}' failed due to the following error: The application called an interface that was marshalled for a different thread. (Exception from HRESULT: 0x8001010E (RPC_E_WRONG_THREAD)).
at System.StubHelpers.StubHelpers.GetCOMIPFromRCW(Object objSrc, IntPtr pCPCMD, IntPtr& ppTarget, Boolean& pfNeedsRelease)
at iTunesLib.IITIPodSource.EjectIPod()
at MusicBeePlugin.ITunes.Close()
at MusicBeePlugin.Plugin.Eject()
at MusicBeePlugin.Plugin.turnOnEventHandler(Object sender, EventArgs e)
at #=qCYuNPT_pkZhe0BeFvIdrtDcD9U14COGMhEp_wsrpbXKwvnoLUJ9O7I4OR5YKlOxE.#=qJM2HaHQijqTIWfl_v6bREw==(Object #=qrWLIx4rXF2vsyok91tDgrg==, EventArgs #=qPti0zT4oJ59mbeYe4wv8sg==)
i was able to copy songs earlier but now i can't. please help i learned that you have to turn on your ipod each time you wih to copy songs.
Thank You
