Hi Steven,
As mentioned in my earlier posts, i'm using MusicBee on my Samsung Netbook NC10, which has limited screen resolution 1024x600.
My Library contains 950.000 titles on three 4TB USB-drives.
I'm still very happy with your program, but please consider this:
1. In version 3.2 you have increased the line-spacing in the main panel. This has a very negative effect on number of lines displayed on small screens (i.e. 10 instead of 13 lines in lower section; a big difference).
Please restore old spacing or make it optional.
2. As you indicate yourself, the Preferences window can use some improvements. Please make these windows
scrollable or resizeable.
The window size is fixed at 600 pixels (screen height), but the contents overflow this window at the bottom, and I simply cannot reach the lower tickboxes in some subsections, such as General, Player, Now Playing and Library section, even when hiding the Windows Taskbar.
(Lucky for me the Save and Close button can still be reached . . . ;-)
Strangely enough, the Layout (1) , File Converters and Plugin sections
have scrollbars but are still overflowing at the bottom...
3. The same goes for Layout(1) - Main Panel - Customize Layout window (Views Configuration). Here overflow too, the Configure Fields, Apply, Save and Close buttons at the bottom unreachable at 1024x600 resolution.
Surely you can remedy this
Greetings and Happy New Year from The Netherlands,
Cyril Heesbeen.
