Hi! I'm new to MusicBee and I'm dipping my toe in the water of adjusting skins.
I decided to use BeeTunes as my base. So I created a separate xml file in the same directory, and I put in the following code:
<root dependsOn="BeeTunes.xmlc">
<!-- Highlighted File menu color -->
<element id="InlineMenu.ParentItem.Highlight" bg="120,160,255" fg="White" bdr="120,160,255" />
</root>
The goal here was just to change the highlight color when hovering the mouse over the main pulldown menus. However, it didn't do anything.
What basic mistake am I making?
p.s. One thing I noted was that the original line from the BeeTunes source code has the foreground set to white, but the actual text color is black. Does that mean that I'm editing the wrong line? Or that it's being controlled in another way?
