Author Topic: Disable smooth scrolling  (Read 4296 times)
Darmst
I updated to the newest version of musicbee (3.1.6466) and now there is smooth scrolling everywhere and the number of lines moved with each step of the scroll wheel is finger-numbingly low. It's unbearable. Is there a way to revert scroll wheel behavior to the previous stable build?
I'm new to the forums, so I hope I follow the general procedure.
AnalogKid
Bumping this.
I have a large library and the scroll speed is killing me.
Trommy
Me too. I thought i was alone in my wishes  :)
Last Edit: January 20, 2018, 12:30:37 PM by Trommy
i assume you all are referring to the mouse wheel
I am willing to create a debug version if anyone says they are happy to run it.
http://www.mediafire.com/file/636pmgkaca5e3iy/MusicBeeDebugScroll.zip
unzip and replace the existing musicbee.exe
can you scroll a few times and then send me the info at the end of the error log (help/ support/ view error log)
keep your existing musicbee.exe handy and replace the debug version afterwards
One of the numbers is a bit odd. Were you scrolling the main panel or the playing tracks panel and which view are you using for the panel being scrolled?
If it was the main panel being scrolled, were you viewing the library or the "Now Playing" tab?
AnalogKid
https://i.imgur.com/bEMrQul.png
Here's how I have it set up. I scrolled the artist list mostly and I think I scrolled the album list a little too
the column browser is using a lower scroll increment, so i have updated it:
AnalogKid
Thanks, great improvement when scrolling the Radio stations list!
Trommy
Not work with that column (red rectangle)
wollington
Not to beat a dead horse but if we could get the scrolling slowed down for the left panel that would be killer. It makes it seriously more difficult to use the program unfortunately...
Pressing alt key slows down scrolling.
