Author Topic: Filtering by language metadata tag after 3.1 update?  (Read 1003 times)
tsenn
I had all my music tagged by language as a custom tag before I updated to the latest version. All my tags are still in place but I can't filter my music through the thumbnail browser like I did before since the language tag no longer shows up. Could someone please clarify why? Or show me way to properly use the language tag? Thanks in advance.
i expect you would find it in the "Custom Tags" drop-down menu from your screenshot
tsenn
It isn't there, which is what baffles me. It's in the tag editor however.
it was set to be a dedicated tag instead of a custom tag but wasnt included in the filter fields by oversight.
I have added it back in under "Other Tags"
