Author Topic: no bluetooth connection  (Read 2889 times)
jedwar
On my good Dell laptop, I did a clean reinstall of Windows 10, then reinstalled Music Bee. Before all that, it worked perfectly with my Harman-Kardon remote speaker. Now, I cannot get any bluetooth connection. Please help
Are other apps connecting to the BT?
If so, make sure you have the correct Output and Sound Device set in Preferences > Player > Audio Player.
If other apps aren't connecting to BT then I think you'll have to look elsewhere (Windows) as it's not likely to be a problem with MB.
