Author Topic: Album Types (LP's ; EP's ; Singles ; Compilations, etc.)  (Read 86679 times)
The Incredible Boom Boom
I'm using the method where the "Group By" section is using the virtual tag that is blank, so in sub-grouping i'm using the virtual tag that really sorts the grouping in the way i want., also the custom sort that i'm using is: Grouping/ Year (Desc)/ Album
I'm not sure I understand what you're trying to say here. Can you clarify it?
aktor
In music explorer when you group by virtual tag you can make it blank when the tag has no value with this formula for example $IsNull(<Grouping>," ",<Grouping>) but the blank space remains. As i to don't like empty space I have set it so it displays "albums "with with some ornaments when it isn't an Ep, Single etc... I would very much prefer the option with no emtpy space.
•―――•  ۞•――――•      $IsNull(<Grouping>,"  A  l  b  u  m  s  ",<Grouping>)      •――――――•  ۞•―――――•
dalesmedley1990
Any chance of getting all this put into an easy to follow step-by-step tutorial or as a plugin or something?
audioscience
SUCCESS
It's too bad we can't make the headers bigger. I'm going to make a wishlish post to see if Steven can make this all a but more simpler by adding better ordering support for groupings
Nevermind, I was doing it slightly wrong- Have it working at 100% as intended!
Wow! Can this be done under the Album Artist view?
