Author Topic: change language?  (Read 1607 times)
marisa94
Hi I put Portuguese but everything is mistranslated. How do I put it in English?
Do I need to uninstall and reinstall? does not make sense
Sugestion: Insert portuguese(pt-pt) the real and the main Portuguese. The Brazilian translation is a garbage nothing makes sense
You can change to English in the first tab of the preferences dialog.
I suggest you contact the author of the localisation if you have improvements you want to suggest
