Author Topic: MusicBee doesn't load all the songs inside a folder  (Read 1504 times)
TheInvoker
As title says. i don't have to add anything else.
I have 25 songs inside a folder but only 20 in the library
Are all the tracks tagged properly? (i.e. Is the album title and/or album artist -exactly- the same for all tracks?)
Are the 'missing' tracks in the Inbox?
TheInvoker
i don't know how many info the songs have when i get them. if i have to update artist,genre etc, i do once they are loaded in the software
now i added them manually one by one but i wasted 20 min to find out which ones were missing
How are you adding the tracks in the first place?
Latest patches (3.5/3.6)
If you don't have good data (or pay attention to the data) when you "get" them, them MB isn't going to help you. That's the beauty of the Inbox. Put your new tracks in the Inbox and check the data there. -Then- move them to your library.
Hmm. Any chance the missing tracks are duplicates of other tracks in your library?
