Author Topic: Can't Uninstall  (Read 7612 times)
OddJob
The uninstall file is not in any of the MusicBee folders. It does not show up in any uninstaller program or Windows 10 programs and features. I installed the portable program on my D: drive and now I am unable to find a way to uninstall it. I have also reinstalled the program but that did not change anything. Any ideas? Thanks!
Last Edit: August 17, 2017, 03:04:18 PM by OddJob
Is it possible you 'installed' the portable version? In which case all you need to do is delete all the MB files.
OddJob
So the portable version does not have an install file?
CritterMan
  • Now with FiiO M11!
Actually, he's saying it was never installed. That's how portable works. All you need to do is delete the files and it's gone from your system.
Exactly.
Of course that's assuming you're using the portable edition.
