Author Topic: Config/theme show off thread.  (Read 297198 times)
Maschm
This is mine, kinda simple setup, but i like it :)
DarkRed with my own color edit.
hurdlejade
here is mine!
dark skin with slightly bigger font than default.
fossii
Using the wonderful DarkRED Metro version - love it!
Picmaster
Dark - DarkRED Metro
Last Edit: March 25, 2014, 06:47:09 AM by Picmaster
Moshi_
  • http://www.last.fm/user/Moshi_
> How do you get the highlighted unplayed tracks option?
prefs -> tags (2) -> tag handling -> highlighting -> define rules
name: 'playcount is zero'
rule: <playcount> is 0
Then right-click the main-panel header -> other fields -> expose the 'highlight' column
For ages I thought that highlighting would affect the whole row and look garish. I was pleased to find out that it just highlights the column. There's also recently been a new feature added where you can display an icon instead of a colour.
The highlighting looks a bit redundant in the screenshot, since the playcount is also exposed. But when I'm scrolling I can't easily identify the tracks marked '0', so the highlighting just allows me to notice 'clusters' of unplayed tracks easily.
Thanks for this!!!
sierena
DarkRED Classic skin.
I got the big album artwork idea from someone on last.fm and I like it quite a lot.
Kaelri
Love the new "expanded" Album view. The solid colors work well with DarkRED.
MewCore
I updated my config with big covers and artist view.
Lyrics, cover art and artist picture in one view...can't imagine that in other players.
EpicCyndaquil
Probably a dumb question, but how are you guys getting that sweet progress indicator? (Here's an example of what I'm talking about...)
EDIT: Okay, so I see it when I'm in theatre mode, but will it work in main player view?
so_la_la
I don't have anything interesting visually, but I've labelled some features that I don't see other people using too much (click to enlarge):
Can sb explain how to split the library into sections and how to organise playlists in folders? Thanks!
Music Bee 3; EAC; MP3Tag; Music on Synology NAS 115; Logitech Media Server on RPI 3; RPI 2 with Hifiberry; Poweramp for Android/Lineage
EpicCyndaquil
Depends on what you mean by 'sections' exactly. The filters in that screenshot? Right click on Music in the left pane, filters, manage filters. You'll also want to make sure they're showing.
Playlist folders is easy - right click on playlists and choose New Folder.
Pennywize
That`s mine. I also love the new way of the expanded album view. Using iBee Dark as Skin
working hard to get the whole biblio into MB
YamiFrankc
