> How do you get the highlighted unplayed tracks option?prefs -> tags (2) -> tag handling -> highlighting -> define rulesname: 'playcount is zero'rule: <playcount> is 0Then right-click the main-panel header -> other fields -> expose the 'highlight' columnFor ages I thought that highlighting would affect the whole row and look garish. I was pleased to find out that it just highlights the column. There's also recently been a new feature added where you can display an icon instead of a colour.The highlighting looks a bit redundant in the screenshot, since the playcount is also exposed. But when I'm scrolling I can't easily identify the tracks marked '0', so the highlighting just allows me to notice 'clusters' of unplayed tracks easily.
how are you guys getting that sweet progress indicator?
I don't have anything interesting visually, but I've labelled some features that I don't see other people using too much (click to enlarge):
Can sb explain how to split the library into sections and how to organise playlists in folders? Thanks!
Dark - DarkRED Metro
