Author Topic: Searching in playing tracks/queue  (Read 1003 times)
Shadeblast
Hello everyone,
nothing major here. Just wanted to let you know that while typing in the "Playing Tracks" section the letter you already typed in is automatically removed if another one is added. Basically makes searching impossible on larger playing tracks lists/queues.
This happens ONLY there. Searching in Playlists or the Library via the top right box is as fine as can be.
I know it worked before and I am sure this has nothing to do with my configuration
one happy MusicBee user :)
greetz
Shadeblast
Shadeblast
Already was on the most recent build you released.
But just to be sure I downloaded it again and it's still not working as (I would guess) intended.
Just to clarify the element a bit more:
"Right Sidebar", "Playing Tracks" is selected.
The initially hidden search TextBox.
Sorry if my description was not specific enough in the first post.
Stating that you're "on the latest" version really doesn't tell us anything. Steven releases patch versions every few days. I recall something like your issue being fixed a short time ago. So the question remains - what version are you running (help > about) and if it's not 3.1.x, then you should update to the latest patch and report back. See my sig.
i can reproduce this and this should address the issue:
unzip and replace the existing musicbee application file
Shadeblast
Thanks for the fix Steven. Really appreciate it.
@phred: Sorry for not pointing out using the latest released version under the "MusicBee 3.1" thread.
Will remember to post the actual build next time I find something :)
