Author Topic: Adding music in iTunes does not work in Musicbee  (Read 996 times)
smartguy101
Hi
Thanks for some great software.
I've tried to add a file in iTunes, but it won't show up in Musicbee (upon restart).
I have already set up "continously monitor" with the right folder in c:\users\ but still it doesn't work.
if its not showing up on restart then i expect the file is not located in a sub-folder of the folders you are monitoring.
eg. iTunes might be organising the file somewhere else.
Also try updating to v3.1 from the downloads page in case you have any long filenames which MB 3.0 cant handle
smartguy101
Thanks, found a solution in the library section.
Regarding playlists - do you know how to sync between the two programmes?
