Author Topic: Unexpected error  (Read 1794 times)
ankor
MusicBee v3.1.6427.20047 (Win10.0), 10 Aug 2017 9:26:
   at MusicBee.MusicBeeMain.#=qjDPFlLKQ_SLI_FZ5IXjffg==.#=qGQPomskmVwqbPwYOgybo8Q1cFXNb$8nFkRoVztP61lc=.#=qodeIQ0nfzYoF5$FvQpujySj2fhki5FBTJqz5BgKgqAo=()
   at MusicBee.MusicBeeMain.#=qjDPFlLKQ_SLI_FZ5IXjffg==.#=qGQPomskmVwqbPwYOgybo8Q1cFXNb$8nFkRoVztP61lc=.#=qkeWhcM9En_R1dyhlbaHOhQ==(EventArgs #=qiE0FKERQLtrpTj7X0VhtJw==)
   at MusicBee.MusicBeeMain.OnMouseLeave(EventArgs #=qPi1DKzX$pp4HKDkdqrx$5g==)
   at System.Windows.Forms.Control.WmMouseLeave(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=qxD53kMiVis8Q7Eyxmdm7A57NcL0TCX5k0L4V_cGoAyw=.WndProc(Message& #=qAZ_ImC0ogSfIWhvsiPyW6w==)
   at MusicBee.MusicBeeMain.WndProc(Message& #=qTKDo420C4Orxixs6kM60XA==)
this should probably address the issue:
Ladygoshawk
I received an identical error to the one above in ankor's post, and applied the patch-files included in the post below. Once applied, I reopened MusicBee and repeated the same actions that had lead to the original "Unexpected Error" and received a new "Unexpected error" as below:
MusicBee v3.1.6434.35538 (Win6.1), 13 Aug 2017 19:42:
System.ArgumentNullException: Value cannot be null.
Parameter name: key
   at System.Collections.Generic.Dictionary`2.FindEntry(TKey key)
   at System.Collections.Generic.Dictionary`2.TryGetValue(TKey key, TValue& value)
   at #=qCpu_xzIw_sj0QCb$1EjSfgRjfHmw_ZQe9elYr8r1aGNxxNjUWo2bUBky$cdijxbi.#=qnyl78zT6ItUlVvs7U0SBIA==(String #=q2b0wxv2qC6Z_B7XSMmpoBw==)
   at #=qCpu_xzIw_sj0QCb$1EjSfgRjfHmw_ZQe9elYr8r1aGNxxNjUWo2bUBky$cdijxbi.#=qncjSZ6nmH41xbW6Yp5pJgxkATm9xlxHXYHgpggDrqaY=(String #=qTdq_NjfGjIKv0w6V9sGWAw==)
   at #=qCpu_xzIw_sj0QCb$1EjSfgRjfHmw_ZQe9elYr8r1aGNxxNjUWo2bUBky$cdijxbi.#=qf6F9MxOOv3xJTEb7H3k_nP$WmBa0_HlApqK8O8vcrQQ=(String #=qqXHrbWlHena5rl4H$aQo_Q==)
   at #=qCpu_xzIw_sj0QCb$1EjSfgRjfHmw_ZQe9elYr8r1aGNxxNjUWo2bUBky$cdijxbi.#=q61i6dqv1BiAH4CgOFREn0UwcjIJxqaaA4uz4R0K9rc8=(#=qsNEQwxE_pjlQVsMLLdoPZA== #=qOY$17z6tw_KC9HSU9u3OQg==)
   at MusicBee.Media.StorageManager.#=qWIVY0zQy2ZFJoA7nDaEyI5yoyEShfsNajirwT1pJils=(#=qsNEQwxE_pjlQVsMLLdoPZA== #=qrZNlyoMmRQBm1q50OUomfQ==)
   at #=q875noht1xY0yHRu91BuvGV0ucnpILPEwNok$TXbPTnc=.#=qkaL0DlxCjimm_HnjEJysI5N5viM6yoBE9D4Tfdc4bp8=(#=qMmn13t973o1i0psMVD_C3A== #=qGpJhaWXGeokXkh13tPGxdQ==)
   at #=q875noht1xY0yHRu91BuvGV0ucnpILPEwNok$TXbPTnc=.#=qFl_6CefZuxlAa3X1F8k3Rw==(SortOrder #=qgPHEu9CZiGdthzr3Sh2TmQ==)
   at MusicBee.MusicBeeMain.#=qzxBNO0guikAvUyoPXht08NhkTuSrIV3ovwvHPZHImL0=(Storage #=qJYErO_cDfz68X8CG1D3dLw==, #=qQF$oQH1zfEa1z$gfx1aY3MsXkeaq8_NTm0pRD79rplS0iqih9Eu9cpBTcYsl9bHx #=qN_drByaP2ud2IA4Jk38gsQ==)
   at #=qBOg7dI4ItLteHOLh_Br8ykFO_QUsPqFNfN5nCYPMxxk=.#=qYm0gVT1Y6NIkpxxcAFv5dsmhd5qSi$7xpvXJ6XQOFVU=(#=qriD2rWgi8swRDQB7vOaD8A== #=quXHayYrifoaR6juLlk9TpQ==, Boolean #=qArl_JudpOIPHR_tOYMtCCif8HwDIdaeKs2zMzPhVdxQ=)
   at #=qiZU$JnsfJpfaegA5nyHHOxBn2siOtzxAnow0_YCnoR4=.#=qriD2rWgi8swRDQB7vOaD8A==.#=qycHYFD0X3Og20o8YbVay1cnMSH2EkD6wrdjXnYplUh0=()
the errors are completely unrelated. For the portable device error i wont be able to help. The device is returning null for file filename or the parent folder id of a file referenced from a playlist when trying to retrieve playlist files
Last Edit: August 14, 2017, 07:09:52 AM by Steven
Ladygoshawk
Thanks for the quick reply! Sad you can't help, but your information does at least give me a place to start looking for solutions!
I changed my mind after i posted that and will put in some code to suppress the error. I will make that available tonight
could you try this version.
I would be interested to know if it is able to read any files from the playlists
