Author Topic: DAC settings help please  (Read 2180 times)
nicknack35
Hey all could someone explain to me please . i have a MF V90 DAC now if i direct sound i can enable 32bit output but if i use WASAPI mode then i can't use the 32bit my DAC says 24/96 but im sure it can perform 32bit is WASAPI mode till the best option to use thanks
vincent kars
WASAPI talks straight to the audio device.
Hence what you send to it, must match the properties of the DAC exactly.
MF says
•   1x RCA coaxial connector SPDIF 32-192 kbps (16-24 bit stereo PCM)
•   2x TOSLINK optical connector 32-96 kbps (16-24 bit stereo PCM)
•   1x USB type ‘B’ connector - Asynchronous data stream at up to 24-bit/96kHz (Determined by source file/computer settings)
24 is the max bit depth supported by your DAC
