Author Topic: Any sync attempt after 1st fails. Also, only 1 playlist will sync at a time.  (Read 1718 times)
MCDoubleDefDP
Ever since upgrading my Nexus 6P phone to the Android O DP2 a couple months ago, syncing my phone continually fails the second time after a successful initial sync. Also, only a single playlist will transfer if I select multiple ones (I think the last one to sync sticks). I have to disconnect/reconnect my phone to resync my phone.
In other words:
* Sync #1, Playlist A B C = Sync success, Playlist C(?) sucess, Playlist A B fail
* Sync #1+X, Playlist A B C = Sync fail, Playlists fail, the following error is given:
MusicBee v3.1.6403.39709 (Win10.0), 16 Jul 2017 23:58:
System.Runtime.InteropServices.COMException (0x80070141): The device is unreachable. (Exception from HRESULT: 0x80070141)
   at PortableDeviceApiLib.IPortableDeviceProperties.GetValues(String pszObjectID, IPortableDeviceKeyCollection pKeys, IPortableDeviceValues& ppValues)
   at #=qZgBI88Wvo_mufBbdMdUOQLMsIRIWRxEUNB_RmUu_j4yu_UZCZfnYBL$PIEoBhIMR.#=q8u8k6SDqtHMKPETbqGu__A==(IPortableDeviceProperties #=qwIEHliORefzxXUXmHM_HyI45G8C0HMnpRuwBJdHjC_o=, String #=qat5tg_wDcx2V7vKZy1s$8A==)
   at #=qZgBI88Wvo_mufBbdMdUOQLMsIRIWRxEUNB_RmUu_j4yu_UZCZfnYBL$PIEoBhIMR.#=ql9TveigW9i0rIRMUb4Ip8Q==(String #=q2rQX46V2oODReLxUX89S3w==)
   at #=qZgBI88Wvo_mufBbdMdUOQLMsIRIWRxEUNB_RmUu_j4yu_UZCZfnYBL$PIEoBhIMR.#=qeixBTjHlC33xeEKCwJU3zIlk2avaBFrkU6LI7RNDNHo=(Boolean #=q12ySEmFG4N9I1hIo3j4jVA==)
   at MusicBee.Media.Storage.#=qSZMva9q7xTlj0c6QTGAPxw==(Boolean #=qTq39ixkxdTct4Y_4$CGGzg==, Boolean #=qRe$aBxygf8arvS1GqZYCMg==, Dictionary`2 #=qBJqUUGSgTux2dK6M1v6lGx4RcIi1OvyXVY5PWQ_BKwI=, List`1 #=qQmIMPfOM9IBbagzI5CYMoo4_rD6PhrSyTZZvAQ3XfAY=, Object #=qfqDnTZYDQtOb4m8WJx7O7Ps9SgxG3JoyXh93Etff9hY=)
   at MusicBee.Media.Storage.#=qw_FkAuZ6OtQzCZo8yvSiVw==(Boolean #=qW9j9oeL7ii4GmaOlRBdRxA==, #=qR$17GapS8fqAi$dV_dfiHMjwrrQg_bS8ILv4pVOR_Og= #=qha$Lo4pDGy7Gfh10UHCrMQ==, Object #=qe46gAov7Iu$YusmJ4jN5aVe2GYXIMT6AjvE0ZeV2HSI=)
   at MusicBee.Media.Storage.#=qixvMzCtBeoOvdtVIYrs2cw==(#=qR$17GapS8fqAi$dV_dfiHMjwrrQg_bS8ILv4pVOR_Og= #=qFMS5DkQSAqZfTwOnVsSwTw==, Object #=q1wyFozWs28f1ND2PA7QUnV9A9CfFftju1VrWucF$5sk=)
   at #=qTkl2SbjZ5hWTTnioi3489BS8emOQmzUTztiH8ulY$yY=.#=qaZ8Rbzc874$tCOSySxZu1Pb7ukN1ldO6LvmVqPccG0Y=(Object #=qRiPfMWY60JPhOwoy_ExEhw==)
This might be an error exclusive to the Android O beta, but I'm reporting it anyway because I haven't seen anyone else do so. I hope this is helpful.
Thanks!
