Heh, context & syntax.
I approached it from the other side... I used 'colour + text' first (without Icon, or the 'highlight' column), and discovered that 'colour' in this context also means a 'colour icon' automatically in hindsight, which felt odd (as it only surfaced, and got in the way of what I wanted to achieve... once I showed the highlight column) and the coloured text was a secondary feature, which I used as the primary...
But yes, if someone could move it over to the wishlist section, that would be great!
I'd indeed love to have options ( [ ] = tickbox, [...] = combobox/value) for :
[ ] user icon
OR [ ] color icon (for the highlight column - with an option for NONE if neither is ticked) )
AND / OR text formatting via :
[...] (for setting global or user defined column(s) the formatting is active for)
[ ] colour
[...] (for setting colour value)
AND / OR
[ ] font
[...] (to assign font type / font formatting, i.e. italic, bold, etc))
Hope that makes sense...
Would make for some pretty powerful stacked formatting & multiple highlighting per row rules... but could get messy as well... especially for the preference panel.
Churs.
c.
