Author Topic: Failed to save synchronized song lyrics  (Read 5132 times)
stardepp
When downloading a synchronized lyrics of Minilyrics in the music file, MusiBee shows me this error.
What can be the cause?
https://drive.google.com/open?id=0B9ORseKzkzUcMktjZGZRUF9fUlE
in english: Can not save song text: The object reference was not set to an object instance.
Last Edit: July 15, 2017, 09:10:57 PM by stardepp
check the error log (help/ support/ view error log) and if there is an error dump around the time of this happening then post that.
Otherwise there isnt much i can do with such vague information
can you try using the latest patch version as i suspect it might already be fixed:
stardepp
Yes, but this update has already made it better. But all synchronized song lyrics are still not stored and he will display this error message. Can this be related to the fact that my entire music collection is stored on an external hard disk?
Otherwise, I am very satisfied with MusicBee.
the errors in the error log you sent indicated the last version you were using was an earlier 3.1 version and not the one from the link i provided.
if its still happening with that version then can you confirm you are happy to run a debug version
stardepp
Yes, unfortunately the problem still exists, also with the version 3.1.6407, briefly, almost every synchronized lyrics was saved, but in total only about every 10th. Yes, I would like to try a debug version.
Last Edit: July 22, 2017, 01:39:54 PM by stardepp
could you post the last error in the error log as a reply (help/ support/ view error log)
unzip and replace the existing musicbee.exe
When the error happens, open the error log. I need the information at the end which says "line="
http://www.mediafire.com/file/02y1k6hjv80pjms/MusicBeeDebugMiniL.zip
stardepp
stardepp
I've been testing for quite some time, but it has not gotten any better with saving synchronized song lyrics, it only works with every fifth attempt. I need the information at the end, which says "line =", which I could not find in the error report. Therefore I send the entire error report.
https://drive.google.com/open?id=0B9ORseKzkzUceVMwbWlJZ0JYaTA
I gave you a debug version to run and according to the error log you havent been running it.
I am not willing to spend any more time on this.
edit:
i see now you did run it for a while. However its much too late now and you really should have reported the results sooner.
Last Edit: August 13, 2017, 10:09:58 PM by Steven
