Author Topic: File Converters  (Read 4037 times)
it does sound plausible its the WMA settings as they are quite different to everything else and although redwings suggestion is a good one and feasible, i dont feel i have the time available to implement something that might only affect very few people.
Then, if you want to continue to use MB at the current state, I'd suggest configuring a few command-line conversion commands you're using most often in Preferences> Tools. Then you can run it by select tracks> Send to> External Tool menu.
