Author Topic: Store ratings in music file changes modification date even though it's disabled  (Read 5026 times)
Morbeas
I really need help with this. I literally opened MusicBee, went to a random song (Blackened by Metallica in this instance), right-clicked on it, selected Edit, went to the Lyrics tab, clicked on Search Internet and clicked Save. It updated the file modification date as seen in the screenshot below. What could be causing this?
Is there another way to ask for support?
ma_t14
Morbeas
What happens if you disable the "also save id3v1 tags" option?
Same result.  :(
Morbeas
I also get this flashing exclamation point. Any idea what that means?
It means that you edited the tags with a program other than MB and in order for the changes to appear in MB you need to rescan them.
Select file(s) > Right-click > Send to > Rescan files
Did you read the little pop-up that appeared when you hovered over the red mark? It's on your screenshot and it says exactly what I repeated.
