> I was able to replicate the reported behavior. But I'm not sure it's a bug.
Thanks. I wasn't sure it was a bug, either, which is why I posted in the Questions forum. But the touching of the artwork does seem to suggest MB is trying to do something to the folder.jpg file; maybe it's saving the existing artwork again?
> The problem is your file is linked to the same image file twice. To replicate this, I saved the first image as folder.jpg and add the same image as second artwork with "link to an organised copy of the picture (folder.jpg)" option. Then MB only updates the timestamp of folder.jpg when using search internet for picture command. Why did you organize your artwork that way with duplicate images? Is that something MediaMonkey did?
I don't think so; in MM, I always use a link to the 'folder.jpg' artwork. I don't have images stored as tags in the files (at least, that's my intentions...). MM's artwork editor doesn't show more than one image, unless there really are multiple images (e.g. front and back artwork).
It may be my misunderstanding of MB options; I want MB to save to folder.jpg, and I then want it to link to that image. I originally had the option to 'link to an organised copy (folder.jpg)', but the 'organised' bit, and the ability to create path names from metadata tags seemed to suggest that was meant to put artwork in some parallel directory structure. So I changed the options to 'save to folder.jpg', since that seemed a more direct way of storing the artwork in the album folder. I assumed that saving to the folder would also make a link to that image. Maybe that assumption is wrong, and all it does is save the image, and nothing else (i.e. doesn't change any artwork associations).
Since I want to save any downloaded artwork to folder.jpg, and link to that image to the music files, rather than embed artwork, can you suggest what the most appropriate options would be? And if there's a way to automatically get rid of the duplicates in the MB database (a re-scan after changing the options, perhaps?). Or I could just delete the database and start again.
Thanks.
