Author Topic: PUA.BrowseFox Malware Detected in Ver. 3.1.6388 - False Positive?  (Read 1708 times)
runicen
I attempted to download and install Musicbee Ver. 3.1.6388 via the MediaFire link and had Webroot throw up warnings about the malware program "PUA.BrowseFox" being present in "MusicBeeXBox.dll" immediately after installation.
Has anyone else encountered this?  I immediately uninstalled and went back to Ver. 3.0.6335, which doesn't return this error in my virus software.
Is there a chance this is a false positive or is this something to be concerned about?
False positive.
VirusTotal shows both the exe and dll as clean.
If you're not familiar with VirusTotal, https://www.virustotal.com/en/
runicen
Many thanks for the confirmation.  Seemed odd to me, but wanted to play safe rather than sorry.
EDIT:  I've submitted the file as a false positive to Webroot so, hopefully, anyone else using it won't have to worry about this.
Last Edit: July 02, 2017, 09:56:13 PM by runicen
SoftwareSamurai
I just installed 3.1, and Webroot went all nuts on it again. (This isn't the first time.)
I've also submitted it to Webroot as a false-positive. My guess is that they don't care, and will continue to trigger on it.  :(
Just add the .exe to your webroot whitelist.
