Author Topic: Updating Lyrics? in the main panel  (Read 1603 times)
I was pleased to find that I can actually update the Lyrics? field from the main panel (specifically, to enter the N [no lyrics] value).  However, if I update it that way, the "mark as having no lyrics" box is not actually ticked.
that was never intended to be editable. Although N could be meaningfully entered, none of the other values could
True. I'll stick with the tag editor I guess.
I'm having a different problem with that, though.  If I edit multiple files to have no lyrics and use my save & goto next hotkey, the changes are not actually saved.
Last Edit: June 18, 2017, 03:27:17 PM by psychoadept
Thanks!
