I currently have MB installed, with many updates/patches, backup/restore over time. I experience some issues which are not reproducible on other instances. I'd like to scratch the existing MB installation completely so that I can reinstall MB as clean a possible.
I was thinking of the following procedure:
1. Use the backup function, including the library settings file.
2. Note the layout options as best as possible as I believe there is no 'backup' file that will contain this.
3. Use windows control panel to uninstall MB
4. Remove all files in <user>/Appdata/Roaming/Musicbee if the uninstall did not do that
5. Remove all files in c:\Programfiles (x86)/Musicbee if the uninstall did not do that
6. Reinstall MB
7. The current MB library is on a different drive than the MB executable, so that library folder as library in the settings.
8. Delete the default MB library file
Comments? Anything I forgot?
