Heya,
just came across this and just wanted to log this.
IF you use the 'enable direct editing of tags in main panel' setting, all fields I have tried this on (mostly custom fields...) do correctly autocomplete to single values already present in other fields for this, i.e. for a custom INSTURMENTS field I am populating typing:
P = results in autocomplete suggestion to 'Piano' (for example)
If I do the same in the genre column, I get different behaviour that's probably no intended/wanted,
i.e. when I type:
R = results in autocomplete suggestion of ALL multi value strings starting with R... so I get these as auto-complete suggestions:
Ragga; Hip Hop; Dancehall
Ragga; Dancehall
Reggae
Reggae; Bashment
etc pp (and 100s of more suggestions based on existing recombinations of multi value genre strings found in the library)
Whereas I would think it should only autocomplete suggest the current matching single value, i.e:
R =
Ragga
Rave
Reggae
etc pp
just as the Tag Editor genre field auto-cpomplete suggestions behaves as well...
Hope this makes sense & is easy to reproduce & fix.
Cheers.
c.
