Another one. When opening a new tab, it takes the layout from the last stayed tab. Shouldn't a new tab always use default layout?
I think the issue here is the notion of "default" layout. Current behavior could be useful if users intentionally open a new tab while staying in a tab with a desired layout for the new tab. Then they don't have to select a layout for the tab. But it also means they can't expect a certain "unified" layout for a new tab because it depends on the tab they were at when opening - and that's what "default" layout is about.
Here's another issue - Search Results tab. I tried global search from custom layout tabs, and each search results tab took the same layout as its original tab. How about making it keep its own layout since "global" search doesn't really have a lot do with original tabs and it could be more useful with its own search-oriented layout?
caused MB to not fully load the settings.
No, I can't. But about an hour ago I have experienced it third time. That was right after I edited a sort tag value for a file and save it. Also I think I might have touched sort tag values/settings around the time when the previous two incidents occurred. Do you think that could cause that?
