Author Topic: "Hide player bar" option for compact player  (Read 1765 times)
If you select a TM view on compact player mode, player bar is not needed most of the time. Can you add an option to hide player bar to compact player mode?
i think thats an oversight as when player controls are set to draw on the main panel (for other views) then no player bar shows for theater mode so i will change the behavior to always hide the player bar for theater mode as all theater skins should have a way to invoke player controls
