So I've been playing with the Device sync tool in MB. Everything works great so far.
A few additions I would like to see are:
A time estimate for the sync. I'm currently processing 1732 files so if possible I would like to see a time estimate, even a coarse one.
For the sync preview I would like to see under 'action' a new prompt 'no action'. I had a few albums corrected to a new folder sorting mode, but some albums had updated tags so I saw that only a part of the album had the 'update' action. I was confused whether MB was actually copying them; later I got that the tracks were already correct in my phone so no action was needed. To avoid the confusion I'd like to see the 'no action' under action to confirm that the file is already correct and a copy isn't needed.
An option to see the percentage copied on a per-track basis. E.g. 50% of X file copied, when at 100% change it to just Copied and move on.
None of these are critical, more 'quality of life' improvements.
Thanks a lot Steven for your continued efforts on Musicbee
