Author Topic: Custom Tag & Configuration.xml changes preview  (Read 1447 times)
alec.tron
Heya,
when changing global tags and/or the Configuration.xml (which is unfortunately necessary after every patch update that also pushes a new Configuration.xml for me due to this: https://getmusicbee.com/forum/index.php?topic=18424.msg128173#msg128173 )
But even despite the 'INITIALKEY' miss-spelling in the Configuration.xml for ogg-vorbis, it would be neat to be able to test the syntax on a/few files first instead of needing to re-scan the whole library to see if your changes actually worked.
Cheers.
c.
Last Edit: May 14, 2017, 01:23:05 AM by alec.tron
