right click on the playlist node/ Playlist Settings...
and set "custom fields for this playlist only"
that setting also enables custom sorting
OK, forgive me. What is the "playlist
node?" I also can't find any menu item that says "Playlist Settings."
When I right click on anything and everything that I can find on MB that says "Playlist" there is NO option that comes up that says "custom fields for this playlist only"
- On the top of my screen, my options are [playlist that I am currently on], "Now Playing," "Playlists," "Music Explorer," "Podcasts," & "+"
- When I right click on that "Playlists" the ONLY options that come up are, "Edit Tab Header," "Pin Tab [Icon Only]", "Pin Tab [Icon & Text]," "Navigation Lock," & "Close Tab."
- On the left panel, when I right click on "Playlist" My only options are, "Play Now," "Play Shuffled," "Queue Next," "Queue Last," "Edit Auto-Playlist," "List," "Export," "Send To," "Duplicate," "Delete," "Rename," & "New"
Again, there is NO option that comes up that says "custom fields for this playlist only."
Please advise. Thank you.
V
