Author Topic: Fit Artwork to Size of Panel  (Read 3457 times)
Chaython
It should scale around the "album content view" if "Now Playing - highlight playing track in the main panel" is selected.
No matter what album art size I select I seem to have cut off, this is the closest I could get it to not cutting off an album cover
Perhaps removing the padding around the album content would help
Thanks as always!!!
3.1.6336.30947
Last Edit: May 08, 2017, 11:32:52 AM by Chaython
The latest MusicBee patches.
can you send me a link to your settings file (help/ support/ view settings)
everything looks fine to me. If you are refering to the fact that in your screenshot the opened expanded panel has pushed the top pictures up then i wont change anything around that
Chaython
That's what I was referring to, if it's set to fit to panel it only makes sense that it would "fit"/ wrap around the album contents, as the playing album contents are always shown for the playing track.
Please help me  :'(  :-*
I just spent two hours changing my themes and layouts and this is the one thing I couldn't fix.
Also how would I remove the padding, the x from the album details
Also there still seems to be no way to remove last fm scrobbling button?
