Author Topic: <Artwork> field in virtual tags  (Read 4061 times)
  • MB Version: 3.6.8849 P
<Artwork> is available from the field selector in virtual tags creator.
Should the value returned ever be anything besides "Unknown Artwork" ?
Maybe something like "Cover", "folder", "Embedded" or "Linked" ?
(originally posted on Questions board)
_______________________________________________________
Could the <Artwork> field in virtual tags be enabled to provide feedback on the MIME type of artwork, please?
A quick google of the bass library API says it can return the apic code for the picture type and even "-->" for the MIME type to show its a link rather than embedded artwork.
Last Edit: April 25, 2017, 11:58:37 PM by Bee-liever
bummer  :(
I was hoping it was reading if MIME type file was attached and returned the picture type eg. Cover (front) or even just Y/N or T/ F so you could check for embedded artwork.
vzell
as vzell has +1'd this, could a moderator move this thread to the wishlist section, please
alec.tron
If I understand this correctly, then this is similar to this, or rather would enable something like this (?): https://getmusicbee.com/forum/index.php?topic=21265.0
In which case +1 from me as well.
c.
Last Edit: April 26, 2017, 01:24:08 AM by alec.tron
altered to a wishlist request
P.S. thanks for the moving, phred
No problem, Bee-liever.  :-)
