I never transcode files when syncing to device (Android phone). Since the latest Music Bee patch (3.1.6335), when syncing it will try and transcode some M4B files, even though the option is deselected and M4B is supported by my device. This always fails because I have no transcoders setup - so the end result is the file is not copied.
This has only occurred since installing the latest patch. Thanks for any help.
