Is there a way to replace the .asx files in musicbee library to the file that the .asx is referring to? Also, if there is a way, can the replaced song in the library also update the tags/information that have been edited on the .asx? As a side question - is there an easy way to detect which .asx files are broken and can't play songs due to missing files?
Otherwise I will have to go through most of the songs and add them one at a time (through notepad) and reedit each one to match the current .asx ones.
I can also provide additional information if need be.
