Author Topic: Extented View  (Read 1326 times)
Tommy
....... I think there is a bug in the Extended View, but I'm not sure.
Anyway, I thought I let you know.
In the extended view in the main panel, the cover art displayed to the right has a fraction cut off to the left.
Here a screenshot where you can clearly see that the white frame from the cover is cut off on the left side:
In case you need my settings file, please let me know .......
Tommy
karlheinz
hello
the artwork reflection is not cut off but diagonal
when it was introduced for the first time, it was horizontal and looked better
so +1 for a change
This post is about the left side of the image being cut off. It has nothing to do with the reflection being diagonal.
so +1 for a change
You should post your request for a change to the Wishlist sub-forum for consideration.
