Author Topic: Sharing MB library over 2 systems  (Read 1948 times)
bailso
Hi All,
I am now accessing the MB library on one system over wifi from a second system in another room. It seems to be working well with one exception and I have confined my activity to one system at a time.
When I next start MB on one system after using the other I get a start-up message
"Invalid URI. The URI scheme is not valid".Once I press OK the error log opens up with the report
"27/03/2017 11:19:00 AM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
   at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
   at System.Uri..ctor(String uriString)
   at #=q4obheSehcMgJP1Exg7H7x6DkeHKMzahiXMVG
MB then starts and plays without any problems.
Can anyone suggest how I can stop the messages appearing.
Thanks and regards
can you post the full error message - you can get it from the error log (help/ support/ view error log)
bailso
Thanks Steven.
It appears that I am getting a error logged at every startup but I only get the "Invalid URI" and error log popping up the first time after I use the other system.
Here is the error log for the last 3 days, the middle being when the message popped up.
26/03/2017 1:28:54 PM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
   at #=qn3aANF2VEqXOVQUFy$ytVvY5iW7pXHYkU8MYhCHimcE=.#=qFsUbaABy3UwJ7lNvpeJTAQ==.#=qUwdclouv2AUAmbrmprGMnw==._Lambda$__0(IEnumerable`1 #=qSiM$szbuips_g3SVo6sRrw==)
   at #=qWpQ5q1GcA2F$zLil$2GoVhuKE7F4PNW2EU$6RZ2j7Q0=.#=qaT2zOwtvKgXR7VyWX3LB5I1M_D7LUpfciusZEVqrVA0=.#=qzFO6IJb7JwK8Ra2SZx4VkTQV$lEC21TZX267GMCWZxM=(#=qh1xxSQbEj84zcuiXaBgdUtaxnZc8ZaB5SxapkbR9FT7Aka25FtW$Gdd6TVHaqne4 #=qxCzuaqlfcrDPZ3hZaoW7CQ==)
   at #=qn3aANF2VEqXOVQUFy$ytVvY5iW7pXHYkU8MYhCHimcE=.#=qFsUbaABy3UwJ7lNvpeJTAQ==.#=qnsC1wnRTXA67RGW6BIOgJGdZHNrK_tEd0o$JiANdkhw=()
26/03/2017 1:30:58 PM - 10.0.14393.0 - 3.0.6276.35911 - System.IO.IOException: Cannot create a file when that file already exists.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.__Error.WinIOError()
   at System.IO.File.InternalMove(String sourceFileName, String destFileName, Boolean checkHost)
   at #=qdvYyQsLH7PTKSKUyqzGrYSHu_oyIvHW_Hro5GG8IgDY=.#=qr10JuM$eTcKNv2RclpuMjw==(#=qsZTD2eO978r7G4UmDWD91w== #=qHPfNNtKam_9MYamixNENvg==, #=qsZTD2eO978r7G4UmDWD91w== #=qat0kMQOThs3p$PzN_$3TSg==)
   at #=qdvYyQsLH7PTKSKUyqzGrYSHu_oyIvHW_Hro5GG8IgDY=.#=qNKnx5L9DGnmj$i4P_tUTYw==(#=qsZTD2eO978r7G4UmDWD91w== #=qIaXa95lAMzbBRb_FVtDy9Q==, #=qsZTD2eO978r7G4UmDWD91w== #=qro6OVY4Ckj8PRYJP$_71XQ==)
   at #=qWpQ5q1GcA2F$zLil$2GoVhuKE7F4PNW2EU$6RZ2j7Q0=.#=qaT2zOwtvKgXR7VyWX3LB5I1M_D7LUpfciusZEVqrVA0=.#=qrToozI5kphX16x6bDaIrCA==()
   at #=qWpQ5q1GcA2F$zLil$2GoVhuKE7F4PNW2EU$6RZ2j7Q0=.#=qaT2zOwtvKgXR7VyWX3LB5I1M_D7LUpfciusZEVqrVA0=.#=qapZ5afpazhCo6cg6J0xVFA==(Boolean #=qJfZotJdtQVDPOJlZgSZQNw==)
   at #=qn3aANF2VEqXOVQUFy$ytVvY5iW7pXHYkU8MYhCHimcE=.#=qPXPnlw2B8eDuLsNJdqyQuA==()
26/03/2017 6:18:33 PM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
26/03/2017 6:19:39 PM - 10.0.14393.0 - 3.0.6276.35911 - System.IO.IOException: Cannot create a file when that file already exists.
26/03/2017 6:23:02 PM - 10.0.14393.0 - 3.0.6276.35911 - System.UnauthorizedAccessException: Access to the path 'C:\Users\WB\Music\MusicBee\MusicBeeLibrary.bak' is denied.
   at System.IO.File.InternalDelete(String path, Boolean checkHost)
   at System.IO.File.Delete(String path)
   at #=qWpQ5q1GcA2F$zLil$2GoVhuKE7F4PNW2EU$6RZ2j7Q0=.#=qaT2zOwtvKgXR7VyWX3LB5I1M_D7LUpfciusZEVqrVA0=.#=qQv9yekdj_Pxwtdj1Rwkk0w==()
   at #=qWpQ5q1GcA2F$zLil$2GoVhuKE7F4PNW2EU$6RZ2j7Q0=.#=qgCon_RJaErRLk92rNaEZrg==()
   at #=qn3aANF2VEqXOVQUFy$ytVvY5iW7pXHYkU8MYhCHimcE=.#=qa9OhW7BrEPHOBs3CE4XvuQ==()
   at MusicBee.MusicBeeApplication.#=q33DmNFnsYC3mGmewdOX4ug==.#=qAUDU7dXnqqRVZwTvYqNcyA==(CloseReason #=qteAU6_U3TV22lzroCtz6bg==)
26/03/2017 6:58:20 PM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
   at #=q4obheSehcMgJP1Exg7H7x6DkeHKMzahiXMVGtZ$BEzm_GF1zdH5h64P_27nsLtKJ..ctor()
   at MusicBee.MusicBeeApplication.#=qAdMXBg0bKfbK0wNsELJNCBcDgbRwIw1yhgUqKfSbTOI=()
27/03/2017 2:37:06 PM - M:\:Thread was being aborted.
27/03/2017 10:06:28 PM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
28/03/2017 10:15:42 AM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
28/03/2017 10:17:18 AM - 10.0.14393.0 - 3.0.6276.35911 - System.IO.IOException: Cannot create a file when that file already exists.
28/03/2017 10:32:01 AM - 10.0.14393.0 - 3.0.6276.35911 - System.UriFormatException: Invalid URI: The URI scheme is not valid.
bailso
Thanks again for your help.
Here are the two files you requested, the second in a separate reply.
1.
<ApplicationSettings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<SystemUpgradeNumber>8</SystemUpgradeNumber>
<SystemInitialiseOnceOnly>false</SystemInitialiseOnceOnly>
<Path>C:\Users\WB\Music\MusicBee\</Path>
<OrganisationLibraryKeepOrganised>false</OrganisationLibraryKeepOrganised>
<OrganisationLibraryCopySourceFiles2>false</OrganisationLibraryCopySourceFiles2>
<OrganisationAllowReorganiseTagsMissing>false</OrganisationAllowReorganiseTagsMissing>
<OrganisationLibraryMoveNonMusicFiles>false</OrganisationLibraryMoveNonMusicFiles>
<OrganisationLastScannedFolders>
 <string>M:\</string>
 <string>N:\DSD to Wav 24 - 88\</string>
 <string>N:\FLAC HD\</string>
 <string>N:\Vinyl\</string>
</OrganisationLastScannedFolders>
<OrganisationLibraryExportTagData>true</OrganisationLibraryExportTagData>
<OrganisationMonitoringCheckStatus>true</OrganisationMonitoringCheckStatus>
<MusicOrganiseEnabled>true</MusicOrganiseEnabled>
<MusicFromFolder>C:\</MusicFromFolder>
<OrganisationLibraryMusicFolderPath>\\MUSIC2\MusicBee\Music\</OrganisationLibraryMusicFolderPath>
<OrganisationLibraryFilenameRules>
 <NamingRule>
  <Field>31</Field>
  <Text>\</Text>
 </NamingRule>
 <NamingRule>
  <Field>30</Field>
  <Text>\</Text>
 </NamingRule>
 <NamingRule>
  <Field>53</Field>
  <Text> </Text>
 </NamingRule>
 <NamingRule>
  <Field>65</Field>
  <Text />
 </NamingRule>
</OrganisationLibraryFilenameRules>
<ABOrganiseEnabled>true</ABOrganiseEnabled>
<ABFromFolder>C:\</ABFromFolder>
<ABFolderPath>\\MUSIC2\MusicBee\Audiobooks\</ABFolderPath>
<ABFilenameRules>
 <NamingRule>
  <Field>30</Field>
  <Text> - </Text>
 </NamingRule>
 <NamingRule>
  <Field>32</Field>
  <Text>\</Text>
 </NamingRule>
 <NamingRule>
  <Field>53</Field>
  <Text> </Text>
 </NamingRule>
 <NamingRule>
  <Field>65</Field>
  <Text />
 </NamingRule>
</ABFilenameRules>
<VOrganiseEnabled>true</VOrganiseEnabled>
<VFromFolder>C:\</VFromFolder>
<VFolderPath>\\MUSIC2\MusicBee\Video\</VFolderPath>
<VFilenameRules>
 <NamingRule>
  <Field>30</Field>
  <Text>\</Text>
 </NamingRule>
 <NamingRule>
  <Field>65</Field>
  <Text />
 </NamingRule>
</VFilenameRules>
<OrganisationPlaylistsFormat2>12</OrganisationPlaylistsFormat2>
<OrganisationExportedPlaylistsMFolderPath>C:\Users\WB\Music\MusicBee\Exported Playlists\</OrganisationExportedPlaylistsMFolderPath>
<OrganisationExportedPlaylistsFormat>1</OrganisationExportedPlaylistsFormat>
<OrganisationExportRelativeFilePaths>false</OrganisationExportRelativeFilePaths>
<OrganisationExportUnixConvention>false</OrganisationExportUnixConvention>
<OrganisationAddNewMonitoredFilesToInbox>true</OrganisationAddNewMonitoredFilesToInbox>
<OrganisationAddNewMonitoredFilesToNowPlaying>false</OrganisationAddNewMonitoredFilesToNowPlaying>
<OrganisationContinuousMonitoring>false</OrganisationContinuousMonitoring>
<OrganisationDetectDuplicates>false</OrganisationDetectDuplicates>
<OrganisationIncludeVideoFiles>false</OrganisationIncludeVideoFiles>
<OrganisationIgnoreSmallFiles>false</OrganisationIgnoreSmallFiles>
<OrganisationIgnoreSmallFileSize>20</OrganisationIgnoreSmallFileSize>
<OrganisationAutoSweep>false</OrganisationAutoSweep>
<OrganisationAutoSweepTargetPath />
<OrganisationAutoSweepNaming>
 <NamingRule>
  <Field>31</Field>
  <Text>\</Text>
 </NamingRule>
 <NamingRule>
  <Field>30</Field>
  <Text>\</Text>
 </NamingRule>
 <NamingRule>
  <Field>86</Field>
  <Text> - </Text>
 </NamingRule>
 <NamingRule>
  <Field>32</Field>
  <Text> - </Text>
 </NamingRule>
 <NamingRule>
  <Field>65</Field>
  <Text />
 </NamingRule>
</OrganisationAutoSweepNaming>
<OrganisationMonitoredFolders>
</OrganisationMonitoredFolders>
<SubscriptionRefreshInterval>3</SubscriptionRefreshInterval>
<SubscriptionDownloadPolicy>0</SubscriptionDownloadPolicy>
<SubscriptionKeepPolicy>0</SubscriptionKeepPolicy>
</ApplicationSettings>
you need to send the files as links to a location you have uploaded them eg. mediafire.com
but in any case i can guess what is happening:
- MB is failing because its attempting to open the remap file paths dialog and i expect there is some bug with remaping from a UNC path to a drive letter path
- to stop triggering MB to do that, you would need to run seperate installations of MB and have MusicBee3Settings.ini located on each PC ie. you shouldnt run MB with a shared settings file if the file path to the shared library is different from each PC
- its ok to shared a single instance of the library database and the library ini file (MusicBeeLibrarySettings.ini)
