Author Topic: Sync support for portable players with multiple SD card slots.  (Read 5067 times)
CritterMan
  • Now with FiiO M11!
There are a number of mid and high-end portable music players on the market that have more than one microSD or even full SD card slots. In addition, some have internal storage that can be synced to as well. I don't know how many MB users have them, but if there are any that would like to have their library span multiple cards please +1 this.
I have two portable players that support two 256GB microSD cards, the Fiio X5 gen 2 and the gen 3. Currently, MB can only sync to one card or the other, but what if it could sync to both simultaneously? That would allow the music files to sync some of the files to one card, and the rest of the files to the other. Also, playlists can draw from both cards. On these two Fiio models, the path prefix for tracks would be:
X5 gen 2:
A: or TF1:
B:  or  TF2:
X5 gen 3:
/mnt/internal_sd
/mnt/external_sd1
/mnt/external_sd2
Just in the Fiio line alone, a total of six models can reference tracks on multiple drives in the same playlist. It would be awesome if MB could sync a library between multiple cards and create playlists that can include tracks from all of them automatically.
theG
+1
I'm really close to have my microSD card full and will have to expand on my phone's internal storage.
This has come up several times so i will look into it.
The first thing i will need to do though is give you a debug version to see if MB is able to detect the sd cards and how they look, so let me know you are happy to run a debug version for that
CritterMan
My home install is portable, so I can run any version you like. I'm on Win7 x64.
could you run this version - it will add entries to the end of the error log (help/ support/ view error log). Its just basic info on the attached devices and storage.
http://www.mediafire.com/file/jt5uljsb442le4j/MusicBeeDebugStorage.zip
i might need to do this again
CritterMan
PM sent.
spwood
Has there been any progress towards syncing for devices with multiple SD cards?  I, too, have a Fiio (X5 III) and there doesn't appear to be a Windows program that will sync the PC's music library onto a device running two SD cards simulataneously.  More and more portable players are using this configuration, so there is a current need that will only increase!  Thanks.
JohnnyPhantom
Hate to resurrect this old topic, but I would LOVE to see this happen. I have a Fiio X5ii with 2 MicroSD 256GB cards and would love it to sync to both of them.
