Author Topic: original artist (TOPE) doesn't use the "multiple tag splitter"  (Read 3048 times)
vzell
The newly introduced "original artist" (TOPE) tag doesn't use the "multiple tag splitter". According to the spec
TOPE
    The 'Original artist(s)/performer(s)' frame is intended for the performer(s) of the original recording
Additionally when entering ";" separated entries they do NOT show up as separate entries in the Library Explorer
as can be seen in the following screenshot
Can this be implemented like the standard artist/composer/conductor ?
telmer6
+1
It would also be nice if the "Original Artist" and "Original Title" fields pulled suggestions from the "Artist" and "Title" fields respectively.
original artist is now fully supported for multiple values in the next v3.5 update
Last Edit: March 19, 2022, 09:21:28 PM by Steven
...in the next v2.5 update
I assume you mean the next 3.5 update, yes?
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
