Author Topic: no scroll bar in now playing bar  (Read 1988 times)
  • MB Version: 3.6.8849 P
wasn't really a problem before, but with all the extra entries in the artist/role splitter in 3.1...
a little thin scroll bar on the LH side (as done with the lyrics in the Now Playing Panel) would look good  ;)
i acknowledge the issue but its not straight-forward to address using a scrollbar.
what field are you displaying?
the one causing the long list of entries is Artists: Performer
CritterMan
  • Now with FiiO M11!
I feel this pain.
I will revert <Artists: Performer> to its old behavior and create a new display field for the combined list.
Any suggestions for a name for the new one welcome.
I might just user <Artists> for the combined list
CritterMan
Performers: Combined?
Will this impact on the 'Track Information' panel behaviour?
Really don't want that to change. It already works well as it has a scroll bar.
@CritterMan, you can restrict the number of rows displayed for each field in the panel configuration
@Bee-liever, i will have a look at implementing a scroll bar
Looks good  :)
I know this option wasn't your first choice, so thanks heaps for the extra hard work on fixing this one.
