Author Topic: Wrap text from Comment tag in Track information pannel  (Read 2252 times)
StefanIvanovic
The comments tag is shown as a long string even it has line breaks in tag itself
It would be much better if text is wrapped and shown as:
Label: Verve Records 2004 Canada
5.1 DVD-A 24bit 48Hz
Barcode: 6 02498 62046 5
instead of this:
Label: Verve Records 2004 Canada 5.1 DVD-A 24bit 48Hz Barcode: 6 02498 62046 5
  • MB Version: 3.6.8849 P
Try entering like this:
Label: Verve Records 2004 Canada; 5.1 DVD-A 24bit 48Hz; Barcode: 6 02498 62046 5
StefanIvanovic
Tnx! That did the trick, but I don't see a way to do this other than manually for other albums. But, at least it can be done :)
StefanIvanovic
Actually, there is Max row span option in panel preferences that I was not aware of, I just saw it. I don't think I saw it there before and it does exactly what I asked for in this topic. Sorry, should have looked closer.
tommik
Unfortunately the Max row span is not available across all the tabs. For sure in the Now playing tab with artwork the long tags are simply not being displayed although much of the screen is empty.
The option to wrap tags should generally be available across all Music Bee text fields...
Last Edit: March 23, 2017, 08:16:48 AM by tommik
