Author Topic: [solved] Inbox - Sorting by path is behaving different than elsewhere  (Read 59 times)
alec.tron
Heya,
looks like the inbox, if sorting by 'Path' is behaving differently than the standard tracks view. As is in 3.1.6287 Path does sort by path, but ignores secondary sorting / the fileName alphabetical sorting.
i.e. in main library tracks view, sorted by Path only, I see this:
/filePath/01_fileName.ext
/filePath/02_fileName.ext
/filePath/03_fileName.ext
/filePath/04_fileName.ext
/filePath/05_fileName.ext
In Inbox, sorted by Path only, I see this:
 (random example... not necessarily in that order... but definitely not alphabetic by fileName as a second sorting facet, which seems to be the default in standard tracks view now).
Cheers.
c.
Last Edit: March 20, 2017, 08:33:14 AM by alec.tron
path only sorts the file path. To sort the entire file location (path+filename) you need to sort by URL
alec.tron
Heh, interesting. URL is indeed what I am after...
Then what I saw over the last weeks was all coincidence i.e. that most in my inbox when looking at it was non-URL and everything in my main library, despite only being sorted by path, was alphabetical...
Thanks for the info!
c.
