Author Topic: ALT key opens menu right away, should open on press release.  (Read 1818 times)
theG
Using the lastest 3.1 patch version (3.1.6286), when you press ALT, the application menu opens right away. I believe the normal behaviour should be the menu to open on press release and not simply on press.
Keeping the ALT key pressed results in the menu opening/closing/opening/closing/opening/etc... really fast.
Using ALT+TAB results in MusicBee menu staying opened.
Last Edit: March 19, 2017, 05:14:13 PM by theG
theG
Thanks, but it's still acting weird.
Using the mouse, when you click on the menu, it opens. Once opened, when you click again it should close but instead it closes and reopen right away.
Same behavior using the ALT key.
