I realized that also for the portable version paths in MusicBee3Settings.ini are stored absolute and not relative. This leads to problems when e.g. moving the folder or transfering it to another computer (which is why you want a portable install). So my suggestion is:
a) make path storage in the portable Version relative, or,
b) include a configuration option to store all pathjs relative in the config (maybe the better option)
Would be nice to see this!
Thanks and cheers, drjee
