Author Topic: How can I add Podcasts?  (Read 2809 times)
snwflake
So, basically on my first startup after installation I cleaned up all the Tabs, created my playlists and so on. Now I came across a (probably the first interesting to me) podcasts and I can't add it, because I deleted the tab. Is there any way I can get the podcast tab back?
This is my current window
You need to configure MB preferences.
control+O (that's the letter O, not a zero) > Layout (1) > left sidebar > podcasts (check the box) > save.
The podcast node will appear in the left sidebar. Click on it and it opens in a tab which you can then pin as a tab if you wish.
snwflake
