Author Topic: File Format for Syncing Playlist  (Read 1214 times)
MoCommodore
If you want to sync your auto-playlist to your device and want to sync it to its own folder on the device, you will always get the playlist number at the beginning of file name. In fact, you have no control on the format of file name on the device.
It would be great if there an option for that, or at least, it uses the format we can set for "Music" files.
I explained my problem in the following topic:
http://getmusicbee.com/forum/index.php?topic=21247.0
xizor81
+1
Yep, that would be great: having a naming convention for files when using "Create a sub-folder for each playlist and its tracks"
Thanks!
Last Edit: May 09, 2017, 01:31:19 PM by xizor81
