Heya.
I changed a few file names, so usually when that happens, I then restart MB, wait for the Remove From Library Confirmation dialogue to pop up (which usually takes about 30-90 seconds), then confirm to remove the files from library, go to inbox where the files with new names appear (usually after the pop up f removal confirmation), send to library & fix playlists if any were affected...
Now, after I updated to 3.1.6279 a few days ago, something is off with the library scan.
As is, I'm 20 minutes after the rename of files & the MB restart, and neither does MB detect the removed files, nor the newly added ones (same files under new name...).
It could be just slower... but I have a hunch something failed silently...
Does anyone else see similar things ?
Cheers.
c.
