Author Topic: Add _gsdata_ folder to excluded folders  (Read 1639 times)
sadsack5000
My wishlist:
Please add the system folder generated by Goodsync to your list of ignored folders during a scan.
The folder is exactly _gsdata_
Im sure there will be more of these types of request so perhaps a feature whereby the user can specify folder exclusions would be easier to manage into the future
Thanks
For the next v3.1 update  I have added support for excluding folders from the monitored folder list. You select the excluded folders yourself in the Library/ folder monitoring preferences
